Giải bài này theo ACI 318-25
2 phản hồi 4.223 lượt xem
#19454
Anh Hùng giúp em giải bài này theo ACI 318-25 với ạ A rectangular concrete beam of width b = 24 in. is limited by architectural considerations to a maximum total depth h = 16 in. It must carry a total factored load moment M = 400 ft-kips. Design the flexural reinforcement for this member, using compression steel if necessary. Allow 3 in. to the center of the bars from the compression or tension face of the beam. Material strengths are fy = 60,000 psi, and fc’ = 4000 psi. Select reinforcement to provide the needed areas, and show a sketch of your final design, including stirrups
